Some customers using a Smart Hub Plus or Smart Hub 3 may find that certain devices or Wi‑Fi extenders won’t connect to their Wi‑Fi. We’re working to fix this, but you can try the steps in this article to reconnect.
Fix a problem with broadband and Wi-Fi
Help articles for fixing broadband problems
Smart Hub 3 Wi-Fi -
Full Fibre help Get help ordering and activating Full Fibre (Fibre to the Home) and troubleshooting problems.
BT Broadband connection problems Save time on the phone if you're having BT Broadband problems, here are some tests you can run at home to try and resolve it.
I want to improve my Wi-Fi Read how to connect 5GHz and dual band devices wirelessly, split your hub's wireless network name and connect to your hub (router).
Help with Wi-Fi problems Get a more powerful Wi-Fi connection on your device with simple changes like changing its location, upgrading to Halo, giving your device a break or using fewer devices.
Fix problems with Complete Wi-Fi Fix any Complete Wi-Fi problems you might have with your hub (router) or discs. See what the different lights mean and how best to connect a disc.
I have a problem with Halo What to do when you're having problems with your 4G back up connection (Halo) or problems with a 4G Mini Hub.
Solve issues with older devices If older devices do not connect to your Wi-Fi, turn on Compatible Wi-Fi on your BT Smart Hub. This creates a 2.4GHz network that helps older or smart devices connect more reliably.
What do the lights on my BT Hub mean? Find out what each light on your BT hub means and how to fix common broadband issues.
Can't connect devices Read how to connect your devices to wi-fi, disconnect from a BT hotspot, and how to connect using an ethernet cable.
Wi-Fi signal in your home Improve slow Wi-Fi signal issues with five practical steps to boost Wi‑Fi signal, fix common broadband problems and speed up your connection.
Can't connect to a Wi-Fi network Discover why you can see a Wi-Fi network but can’t connect. Learn common causes and troubleshooting tips to get your devices online quickly.
Run the wholehome app’s set-up again Learn how to rerun the BT app’s setup without losing your settings. Follow simple steps to automatically restart and reconnect your Complete Wi-Fi discs.
Factors affecting Fibre speed To get the right advice, tell us which kind of broadband you've got.
Complete Wi-Fi firmware updated, app shows update Learn how to fix the BT Complete Wi-Fi app showing an update required after you’ve updated the firmware. Follow these quick steps to resolve the issue and keep your discs running smoothly.
Why am I paying the normal monthly broadband charge? Find out why your BT bill shows the standard broadband charge and when promotional discounts start. Check your billing cycle in My BT.
Common browser error messages Read information about the most common error messages you might see while using the internet.
Run a line check There may be an issue with your broadband, log in to My BT to run a test on your line.
