Back
Help with Wi-Fi problems
Faster than a phone call
Login and we'll test your broadband connection to find any problems you may have, 24 hours a day.
From slow speed to a dropping connection, we'll be able to restart your router or book you an engineer visit.
Test your broadband
Test your broadband
Here are a few things you can do to help your devices get a stronger Wi-Fi signal.
Location, location, location!
It's vital to put your BT Hub in the right place - ideally near where you use the internet most. Solid surfaces like walls, doors, wardrobes, fish tanks and cupboards will all affect your Wi-Fi signal.
Follow our tips to get the best signal:
  • Position your hub in the middle of your home. This will reduce the number of walls slowing down your signal, and you'll get better Wi-Fi in more places in your home.
  • Keep your hub away from the window; half your signal will be sent outside.
  • If you put your hub in a cupboard, it'll slow down your speed and reduce how far your signal can go.
  • Get your hub off the floor onto a shelf or table. If it's on the floor, much of your signal will be reflected into your floorboards.
  • Don't put it behind the TV or on top of a metal box. Metal objects reflect and scatter your signal.
Get the latest kit
At BT, we're always improving our Hubs. Our latest Smart Hub delivers a powerful Wi-Fi signal and a superfast, reliable connection in more places around your home. You can get one by upgrading your broadband package.
Get the latest BT Smart Hub
Give your devices a break
  • Turn off Wi-Fi on your device (or put it in airplane mode for a few seconds), then switch the Wi-Fi back on.
  • Restarting your devices once in a while will help you get the best connection to your home's Wi-Fi..
Upgrade to Halo - now with a Complete Wi-Fi Guarantee
Complete Wi-Fi extends your Hub's signal with Wi-Fi Discs so you can get online throughout your home.
If you get Halo with Complete Wi-Fi, we'll automatically send you our new-generation Smart Hub and one Wi-Fi Disc to extend the Wi-Fi signal throughout your home. This is enough for most homes to get a signal everywhere. If this doesn't give you a signal in every room, we'll send up to two more Wi-Fi Discs free of charge.
Learn more about Complete Wi-Fi
Thanks for your feedback
Submit
