Back
Fix problems with Complete Wi-Fi
Faster than a phone call
Login and we'll test your broadband connection to find any problems you may have, 24 hours a day.
From slow speed to a dropping connection, we'll be able to restart your router or book you an engineer visit.
Test your broadband
Test your broadband
To use Complete Wi-Fi you'll need a Smart Hub, we'll have sent you one when you ordered Complete Wi-Fi. If you've not received it, phone us on 0330 123 4150.
When you first plug in your Hub, please wait for it to sync - this usually takes a few minutes.
Light statusWhat it meansWhat to do
Solid GreenYour hub is starting upLeave your hub to start up. If the light remains solid green for 5 minutes, first check you're using the power adapter provided with your hub, then reboot your hub. If you're experiencing problems, see the help section in your user guide.
Flashing OrangeYour hub is connecting to broadbandGive it 5-10 minutes to connect. The light will then turn blue when your hub is ready. If the light doesn't turn blue, check your broadband cable and filter (if you're using one) are plugged in correctly.
Solid BlueYour hub is working and connected to the internetIf you can't get online, it might be your device. Try switching your device off and on.
Solid WhiteYour hub is connected to mobile using Hybrid ConnectHybrid Connect is in use and in resilience mode, keeping you connected.
Solid OrangeYour Hub is working but isn't connected to the internetTry restarting your hub, check your broadband line activation date or connect a Hybrid Connect or Connectivity Backup if you have one. If it's still not working, get in touch.
No lightThe power is off or the lights have been turned offCheck the hub is plugged in, switched on and it's lights haven't been turned off in the Hub Manager.
WPS FlashingWPS Button is flashingWhen pressed, the light on your hub will flash blue to show it's waiting for you to press the WPS button on your computer or device.
When you first plug in your Hub, please wait for it to sync - this usually takes about four minutes.
BlueYour Hub is connected to your broadband okIf you can't get online, it might be your device. Try switching your device off and on.
No lightThe power is off or the lights have been turned off using the Hub ManagerCheck that the Hub is plugged in, switched on and that its lights haven't been turned off in the Hub Manager. If this doesn't fix your issue, contact us.
GreenYour Hub is starting upWait for at least three minutes for it to turn blue. If it stays green, turn your Hub off and on again. If the light still doesn't turn blue, use a paper clip to press your Hub's factory reset button. If this doesn't fix your issue, please contact us.
Flashing orangeYour Hub is connecting to broadbandGive it at least three minutes to connect. The light will turn blue when your Hub is ready.
Flashing purpleYour Hub is working but the broadband cable isn't connectedCheck if the broadband cable (grey ends) is plugged in correctly. And if you're using a filter, check that's plugged in correctly too.
OrangeYour Hub is working but isn't connected to the internetConnect a device to your Hub. Open a new web browser window and follow the on-screen help wizard to get connected.
RedThere's a problem somewhereUsing the Power button, turn your Hub off and on again. If the light still doesn't turn blue, use a paper clip to press your Hub's factory reset button. If this doesn't fix your issue, please contact us.
PurpleYour Hub is connected to the EE mobile network via Hybrid ConnectThis may be because your broadband connection isn't set up yet, or because there's an issue with your broadband.
WPS button
flashing
 If it's flashing blue, it's waiting for you to press the WPS button on your computer or device (you've got two minutes). If it's flashing red, it didn't connect - give it a couple of minutes and try again.
When you first plug in your Wi-Fi disc please wait for the disc to start-up. This usually takes about 2 minutes.
If you see these colours when you’re not starting up your Wi-Fi disc, follow the instructions to try to resolve the problem.
You can change the brightness of the lights on the Smart Hub and Wi-Fi discs independently on the My BT app. Go to Your wi-fi network and then Settings. You can set the lights to off, dim or bright.
If you set the lights to off, we'll still alert you if there's a fault on any device.
You can download the app from the App Store or Google Play Store.
Try relocating your Wi-Fi disc in another place in your home to extend wi-fi further. You can use the My BT app to test alternative locations and signal strength around your home.
If this doesn't work, as a Complete Wi-Fi customer, you're eligible to get up to two extra discs free of charge (based on need). Just pop over to the online troubleshooter and, if you're eligible, we'll send out an extra disc.
You'll initially receive one disc. If you need more, you can request up to two extra discs via the online troubleshooter or by speaking to one of our advisors. We'll be able to see if another disc will solve your problem due to the size of your home or the way it's constructed.
The best way to connect your Hub and Wi-Fi discs is to follow the instructions on the My BT app. On the home screen, select More, Your wi-fi network and then Set up new disc. This will guide you through the set-up and suggest the best location for your disc.
Alternatively, follow the steps below to connect using an ethernet cable. There's one in your Hub box.
  1. Plug one end of the ethernet cable into a yellow port on the back of the Hub and the other end into the yellow port on the disc
  2. The light on the Wi-Fi disc will start flashing blue and will turn solid blue after a couple of minutes
  3. You can now unplug the cable. The light will change to flashing red, but will go back to solid blue after a few seconds
  4. Unplug the disc from the mains and plug it in at the preferred location
If you're still having problems, use our online troubleshooter
Thanks for your feedback
Submit
