Back
Fix connection problems with older devices using Compatible Wi Fi
If older devices will not connect to your Wi-Fi, you can turn on Compatible Wi-Fi on your BT Smart Hub. This creates a 2.4GHz network that helps older or smart devices connect more reliably.
What is Compatible Wi-Fi?
Compatible Wi-Fi is an extra network available on newer BT Smart Hubs. It helps devices that cannot connect to your main Wi Fi.
It is useful for:
  • Mobiles, tablets, and laptops.
  • Printers.
  • Smart devices such as bulbs, doorbells, and cameras.
Compatible Wi-Fi runs at 2.4 GHz, so speeds may be slower than your main network. However, you can use both networks simultaneously, and your devices will still work together.
You can control smart devices across both networks.
Before you start
Turn on Compatible Wi-Fi using Hub Manager
  1. Open a web browser on a device connected to your hub.
  2. Enter 192.168.1.254 in the address bar.
  3. Accept any secure connection warning.
    More about Hub connection warnings.
  4. Select Advanced Settings.
  5. Enter your hub’s admin password (on the pull-out card on the back of your hub, unless you have changed it).
  6. Select Wireless.
  7. Select Compatible Wi-Fi.
  8. Turn Compatible Wi-Fi on.
  9. Choose a network name and password or keep the default settings.
  10. Select Save.
Your Wi-Fi may disconnect briefly. Devices on your main network should reconnect within a minute or two.
Connect your device
On the device you are having problems with, scan for available Wi-Fi networks.
  • Select Compatible Wi-Fi.
  • Enter the password you set.
If something does not work
Cannot access the Hub Manager?
See Security warning when accessing Hub Manager.
Compatible Wi-Fi does not appear?
Restart your hub and try again.
The device still will not connect?
See Help connecting devices to your hub.
Accessibility and extra support
We can help in other ways if you need it:
  • Use Large Text and screen reader-friendly formats.
  • Get one-to-one help if you or someone you care for has additional needs.
  • Contact us through phone, chat, or Relay UK.
Visit Here For You, which covers accessibility support at BT or Contact us.
Thanks for your feedback
Submit
