Back
Fix a problem with broadband and Wi-Fi
Faster than a phone call
Login and we'll test your broadband connection to find any problems you may have, 24 hours a day.
From slow speed to a dropping connection, we'll be able to restart your router or book you an engineer visit.
Test your broadband
Test your broadband
Help articles for fixing broadband problems
  • Full Fibre help
    Get help ordering and activating Full Fibre (Fibre to the Home) and troubleshooting problems.
  • I want to improve my Wi-Fi
    Read how to connect 5GHz and dual band devices wirelessly, split your hub's wireless network name and connect to your hub (router).
  • Help with Wi-Fi problems
    Get a more powerful Wi-Fi connection on your device with simple changes like changing its location, upgrading to Halo, giving your device a break or using fewer devices.
  • Fix problems with Complete Wi-Fi
    Fix any Complete Wi-Fi problems you might have with your hub (router) or discs. See what the different lights mean and how best to connect a disc.
  • Solve issues with older devices
    If older devices do not connect to your Wi-Fi, turn on Compatible Wi-Fi on your BT Smart Hub. This creates a 2.4GHz network that helps older or smart devices connect more reliably.
  • What do the lights mean?
    Find out what each light on your BT Hub or Complete Wi-Fi device means and how to fix common broadband issues.
  • Can't connect devices
    Read how to connect your devices to wi-fi, disconnect from a BT hotspot, and how to connect using an ethernet cable.
  • Wi-Fi signal in your home
    Improve slow Wi-Fi signal issues with five practical steps to boost Wi‑Fi signal, fix common broadband problems and speed up your connection.
  • Can't connect to a Wi-Fi network
    Discover why you can see a Wi-Fi network but can’t connect. Learn common causes and troubleshooting tips to get your devices online quickly.
  • Run a line check
    There may be an issue with your broadband, log in to My BT to run a test on your line.
Need expert help?
Book a visit from one of our Home Tech Experts
Go back to: What can we help with?
