Back
Everyday Phone Nuisance Call Blocker
Product details
The Everyday Phone Nuisance Call Blocker, gives you back control over which calls you want to take and which you want to block
  • Block up to 20 numbers
  • Excellent sound quality
  • Easy set up
  • Long range reception, up to 300m outdoors, 50m indoors
  • Up to 10 hours of talking OR 100 hours standby time
  • See and hear if you have a second call waiting
  • See who's calling before you pick up
  • Easy to read screen shows when you have messages
  • Do Not Disturb mode
  • Save up to 50 contacts
  • Redial any of the last 20 calls you made
  • 1.6 inch amber screen
* You need to have a Caller Display service from your network provider to block nuisance calls and for text messaging features. Charges may apply.
Recycle Logo
Documents
Thanks for your feedback
Submit
Need more help?
