Back
Incoming calls too quiet?
The UK’s ageing and unreliable copper landline network is being retired.
When BT contacts you, take action to avoid disruption to your home phone or broadband services
Further information and support are available on our Connected Together website, or by calling 0330 1234 150.
If you are having difficulty hearing your caller, there are some things you can check. Some phones have a setting that lets you adjust the volume up or down. To make sure it is set properly have a look at the user guide for your model of phone. Also make sure nothing is blocking the earpiece, such as packaging or labels. If this....
  • Some phones have a setting that lets you adjust the volume up or down. To make sure it is set properly, have a look at the user guide for your phone.
  • Also, make sure that nothing is blocking the earpiece, such as packaging or labels
If this doesn't solve your problem, try testing your line and doing some quick checks with our landline troubleshooter.
Thanks for your feedback
Submit
