Back
I can hear callers but they can't hear me?
The UK’s ageing and unreliable copper landline network is being retired.
When BT contacts you, take action to avoid disruption to your home phone or broadband services
Further information and support are available on our Connected Together website, or by calling 0330 1234 150.
The Secrecy or Mute feature has probably been turned on. When the Secrecy or Mute feature is turned on, some cordless phones will show Secrecy On or Mute On in the handset display. See the user guide for instructions on how to turn Secrecy or Mute off.
Thanks for your feedback
Submit
