Back
Why does my cordless phone keep showing Register?
The UK’s ageing and unreliable copper landline network is being retired.
When BT contacts you, take action to avoid disruption to your home phone or broadband services
Further information and support are available on our Connected Together website, or by calling 0330 1234 150.
If your cordless phone keeps showing "Register", please follow these steps: Check the cordless phone and base are within range of each other and are not obscured by thick walls. You may need to move the handset closer to the base
  1. Check the cordless phone and base are within range of each other and are not blocked by thick walls. You may need to move the handset closer to the base
  2. Check the handset and base are within range of each other
  3. Make sure the base is at least one metre away from any large metal objects or other electrical equipment
  4. Register the cordless phone to the base. You will find the correct steps to follow in the user guide for your phone
  5. Check how many cordless phones you have already registered to the base. If you've registered the maximum amount of handsets and want to register another, you must unregister one first. To find out how many cordless phones you can register, go to the registration section of the user guide
  6. Reset the cordless phone and the base. This will change the settings back to the factory default. If you need help, check the user guide
  7. If you still haven’t fixed the problem, please contact the helpdesk. You’ll find the contact details in the user guide
Thanks for your feedback
Submit
