Back
What do the EE TV error codes mean?
Before looking for your error code, why not try our TV and Sport help tool? The help tool can quickly get you back up and running again. Simply click the link below and give it a go. If.....
To look for your error, please type the code, in full, into the box below.
YVM302, YVM305
Follow these steps to try to fix these YVM errors:
  1. For the best possible reception of available TV channels, make sure your TV aerial cable is directly connected to the 'RF IN' socket on the TV box.
  2. Now scan for channels. To do this:
    Press the Home (or YouView) button
    Go to Settings
    TV Channels
    Retune Channels
    and press OK.
  3. All your channel information should now be available
  4. If you're experiencing TV reception issues and need a TV aerial, we recommend having it installed by a professional. BT have teamed up with TSG, an aerial specialist, who can be contacted between 9am to 5pm, Monday to Friday, on 0844 247 0024.
YVM606
You'll need to connect your TV box to your TV using an HDMI cable. Your TV will need to be HD-ready also.
YVM607
  1. Restart your TV, and when the TV turns back on, restart your EE TV box
  2. Remove then re-insert your HDMI cable from both ends at your box and TV, or AV Amplifier if you are using one
  3. If you have a SMART TV please make sure that the TV software is up to date
  4. If you’re connecting via an HDMI switch or AV amplifier, make sure that the software for this is up to date. If it still fails, try connecting directly to the TV
  5. If you still have the same problem, try a different HDMI cable and an alternative HDMI input in your TV
YVM5001
If you receive this error, ensure your TV box is connected to the internet. If you can play catch-up TV, then your box is connected. Now, generate a new connection code on your box by pressing 'Connect Device' again. If you still get the same error message, please try again in a couple of hours.
YVM210
'Sorry, you can’t record on this device’
This error message appears if your TV box lacks recording capabilities. If you want to record, you'll need to get a box with a built-in recorder.
To upgrade your box, call us on 0800 800 150.
IPC6001, IPC6003, IPC6004, IPC6005, IPC6006, IPC6008, IPC6010, IPC6013, IPC6014, IPC6015, IPC6018, IPC6019, IPC6020, IPC6021, IPC6022, IPC6024, IPC6025, IPC6026, IPC6027, IPC6029, IPC6038, IPC6039, IPC6040, IPC6041, IPC6042
Follow these steps to try to fix these IPC errors:
  1. Try to access the BT Player, press the Home (or YouView) button, then scroll to and select BT Player
  2. If you still see the error message, then try restarting your equipment by following these steps:
    • First, restart your Hub
    • Wait for the broadband light on your Hub to go blue
    • Restart your TV box, using the power switch on the back
    • Now, check if you still receive the error
  3. Check that your software version is up to date. To do this
    go to Settings > Software Information > Update Software
    and select OK
  4. Check your On Demand players are up to date by pressing the Home (or YouView) button, then going to Settings > Software Information > Update players & apps and select OK
  5. If you're still having an issue, contact the TV Helpdesk
IPC6009, IPC6012
If the content isn’t available after five minutes, follow these steps to try and fix the errors:
  1. Try to access the BT Player. Press the Home (or YouView) button, then scroll to and select BT Player
    select OK
IPC6023, IPC6002, IPC6011, YVM102, YVM104, YVM105
There's a problem with your broadband that's affecting TV channels. Follow these steps to fix this error.
Connection between your hub and TV box
For your TV box to work, it needs to be connected to your hub. See our EE TV set-up guide.  
If possible, connect using an Ethernet cable. 
If you've set up a connection between your hub and TV box:
Restart your broadband hub
  1. Press the Power button on the back of your hub until all the lights go off.
  2. Wait for 5 minutes.
  3. Press the Power button again until all the lights come back on.
  4. It may take a few minutes for the lights to settle.
  5. The hub light will turn blue.
Once the hub has restarted, retest the affected channels. If you're still getting the error:
 If you're a Full Fibre customer, restart your Openreach modem (ONT)
  1. Unplug the power cable from the modem's socket. If you have a Battery Back Up, don't switch it off at the mains as the modem won't be switched off.
  2. After about 15 seconds, plug it back in.
  3. Wait for the power light to come on.
  4. When the Tel and PON/Optical lights stop flashing and turn solid green, everything's back to normal.
  5. Check the light on your hub is still blue. If it isn't, see our Broadband connection guide. 
If you continue to see the error code, try the following broadband checks:
Ethernet connection
If you've connected your TV box to your hub via an Ethernet cable, try a different cable, or connect to the router via Wi-Fi.
Wi-Fi connection
If you're using Wi-Fi to connect your TV box, try the following for the best connection:
  • If possible, place your TV box within 5 metres of your hub.
  • Restart your hub and TV box so they can reconnect.
  • Make sure there's only one wall or ceiling between your hub and TV Box.
  • If you can't place the TV box and your hub within 5 meters of each other, and you have a Wi-Fi disc, move the TV box within 5 meters of the disc and try connecting to the TV box.
  • If you do not have Wi-Fi discs, extend your home Wi-Fi signal with Complete Wi-Fi.
Connected using a Wi-Fi disc
If you're using a Wi-Fi disc:
  1. Check the Wi-Fi speed coming from the disc. Your broadband speed may not be fast enough to receive these channels.
  2. If the speed is low, try moving the disc closer to your hub if you can.
  3. Reboot your Wi-Fi disc to re-establish the connection to your hub.
For further help setting up and finding the best position for your Wi-Fi Discs, see our BT Complete Wi-Fi Disc User Guide.
Restart your TV box
  1. Unplug your TV box power cable from the wall.
  2. Wait 30 seconds and plug it back into the wall.
  3. Switch the TV box back on.
  4. Now check if you still receive the same error. 
Reset your TV box
If you continue to have problems and your broadband connection is working, try resetting your TV box.
 Still having an issue? 
Contact the TV Helpdesk. 
IPC6028, IPC6030, IPC6033, IPC6034, IPC6035, IPC6036, IPC6037
  1. Try playing a recording; if that fails, try another.
  2. If you still see the error message, then try restarting the equipment following these steps:
    select OK
IPC6016
Follow these steps to try to fix this IPC error:
  1. Try restarting the equipment following these steps:
  2. Enter the BT Player. Press the Home (or YouView) button, then scroll to and select BT Player
  3. In the BT Player menu, scroll across to the 'Settings' icon
  4. Scroll down to ‘Reset EE TV Data’ and press OK
  5. The BT Player will automatically close
  6. Reopen the BT Player (same as step 2)
  7. Now go back to the channel where you got this error
  8. Hopefully this should have fixed the problem, but if you're still having an issue, contact the TV Helpdesk
auth 1999 error code
Follow these steps to try to fix this error:
    • Restart your TV box by switching off the power at the mains. Wait a few seconds, then switch back on
  3. Check that your software version is up to date. To do this,
    select OK
  5. If you're still having an issue call the TV Helpdesk
BTP-300, BTP-3610, BTP-3632, BTP-3653, BTP-610, BTP-632, BTP-653
To fix this error, go to PIN help on EE TV
BTP-302
To fix this, please contact the TV Helpdesk
BTP-955, BTP-956, BTP-967, BTP-1050, BTP-1051, BTP-115B, BTP-202, BTP-15000, BTP-15001, BTP-16002, BTP-9060, BTP-9061, BTP-9062, BTP-9063, BTP-9064, BTP-9065, BTP-9066, BTP-9067, BTP-9068, BTP-9069
Follow these steps to try to fix these EE TV errors:
  1. Reboot your TV box by flicking the switch at the back
  2. Retry the service
  3. If you're still having an issue, please contact the TV Helpdesk
BTP-950
You'll get this error code when there's a problem with playing a title.
To try and fix it:
  1. Reboot your TV box by flicking the switch at the back.
  2. Check our service status page to see if there's an outage.
  3. If there's no outage, then please contact the TV Helpdesk.
BTP-301
You'll get this error code when there's a problem with purchasing a title. To try and fix it:
BTP-951
You'll see this error when too many TV boxes are connected to the TV account. You can only use one box at a time to receive full service (On Demand and Extra Channels).
If you have two TV boxes, you can order an Extra Box subscription to connect both boxes. However, you can't have this if you have Sky Cinema or Sky Sports.
Order an extra TV Box
BTP-954
  1. Update the software by pressing the Home (or YouView) button,
    select OK
  2. Update the players by pressing the Home (or YouView) button
    and select OK
  3. Now retest
BTP-953
    and select OK
  2. Now retest
BTP-115C, BTP-20000
  1. Restart your Hub and wait for the broadband light to go blue.
  2. Reboot your TV box by flicking the switch at the back.
  3. Retry the service.
  4. If you're still having an issue, please contact the TV Helpdesk.
BTP-155, BTP-263
  1. Press the Home (or YouView) button, then scroll to and select BT Player.
  2. In the BT Player menu, scroll across to the 'Settings' icon. This looks like a spanner.
  3. Scroll down to ‘Reset EE TV Data’ and press OK.
  4. Now retest.
  5. Restart your Hub and wait for the broadband light to go blue.
  6. Reboot your TV box by flicking the switch at the back.
  7. Retry the service.
  8. If you're still having an issue, please contact the TV Helpdesk.
BTP-132
Follow these steps to try to fix this EE TV error:
  4. Retry the service.
  5. Test other content.
  6. If you're still having an issue, please contact the TV Helpdesk.
YVM401, YVM501, YVM502, YVM503, YVM701, YVM702, YVM703, YVM704, YVM705, YVM706, YVM707, YVM709, YVM710
To fix these errors:
  1. Check your broadband connection.
    Settings > Signal & Connection > Broadband Connection
    It should show “Connected” next to 'Status'
  2. Restart your Hub and wait for the broadband light to go blue.
  3. Reboot your TV box by flicking the switch on the back, then try again.
  4. If you're still having an issue, contact the TV Helpdesk.
YVM712
To fix this error:
  1. Check the aerial connection.
  2. Rescan: follow the steps for the current missing channels.
  3. If you're still having an issue, contact the TV Helpdesk.
BTP-160
To fix these errors, you'll need to reset the device using either the buttons on the box or the menus.
Performing the reset using the buttons on the box should allow you to keep your recordings, any scheduled recordings, and personal settings you've made to favourites and playlists.
If you're still having problems or can still access the menu, you can reset your EE TV box from the menu. But be aware that this type of reset deletes your recordings and any scheduled recordings. You'll also lose any personal settings you've made to favourites and playlists.
Here's how to reset your EE TV box
AW108
A network issue most likely causes this. Try it again, or check your 'Network Settings' and the download should resume automatically.
YVM913
You’ll see this error when you try to set your marketing message preferences, either during first-time setup or on the settings page. It means that your TV box isn’t connected.
To fix it:
  1. Check the connection between your Hub and TV box. If you use Powerline adapters, restart both adapters and check they're in sync.
  2. Check your box is connected to your network.
    Settings > Signal & Connection > Broadband Connection. It should show “Connected” next to 'Status'
  3. If the 'Wired Connection' is set to 'AUTO' and the 'Network Connection Status' is showing 'DISCONNECTED', try reconnecting by selecting 'Wired Connection' from the menu, selecting 'NEXT', and pressing 'OK'. If it connects, retry the service.
IPC6007, IPC6017
We've encountered an issue accessing your subscription for the channel you're trying to watch. This could be a temporary issue, or the channel may no longer be included in your package.
If you believe the channel is part of your package:
  1. Select Resolve on the error message on your TV box.
  2. Re-test the affected channel.
If you continue to see the error, follow these steps to perform a factory reset on your TV box
Don't have an error code? Here's a list of other problems below, with help on how to fix them.
If you're seeing the wrong TV channels for your area, you can find the help you need here.
Speed checks
To watch a single Extra TV channel with good picture and sound, you need a minimum download speed of:
  • 5Mbps for standard definition (SD) channels
  • 10Mbps for high definition (HD) channels (BT Infinity customers)
  • 44Mbps for ultra high definition (UHD) channels (BT Infinity customers)
Test your speed to make sure your connection is running fast enough.
If your speed isn’t fast enough, please get help improving your speed, or if you're watching in HD, you could always try watching the SD version of the channel instead.
If your speed is fast enough:
  1. Make sure you're using the Hub we provided you with most recently, and not any other router or routing equipment
  2. Check that your TV box is connected directly to your Hub with an Ethernet cable or Broadband Extender Flex 500s, and that you're not using Powerline Adapters.
  3. Restart your Hub, modem and TV box by disconnecting the power supply from the Hub and your box. Wait 10 seconds, then reconnect the Hub. When you have a solid broadband light on your Hub and modem, reconnect the TV box to the power supply. Now retest the channel.
  4. If you're using a SCART cable, try using an HDMI cable for the best viewing experience. HD channels must be viewed using an HDMI cable.
If you're seeing one of these errors, there's a problem with the BT ID details you're using. Please check and try again.
If you enter a password incorrectly 3 times within 15 minutes your access will be blocked for 15 minutes.
If you've forgotten your BT ID details, reset your BT ID.
If you still have the problemplease check our BT Broadband connection problems help page.
If you still have the problem:
  • On the app - Close down any other app you have running, then try uninstalling and reinstalling the app
  • In the web player, restart your browser or try a different browser. If you still have the same problem, try clearing your browser's cache. A reboot of your computer may also do the trick
If you still have the problem, take a look at our BT Broadband connection problems page.
  • In the web player, restart your browser or try a different browser. If you still have the same problem try clearing your browsers cache. A reboot of your computer may also do the trick.
If you're watching EE TV and your TV screen goes pink, your HDMI cable may not be plugged in correctly. Most of the time, this can be fixed by ensuring your HDMI cable is securely plugged into both your TV and your TV box. Once you've done that, switch your TV box off and on again.
If you're still having problems here are a few hints and tips to help you
  • Try reversing or using a different HDMI cable between your TV and TV box
  • It might be a problem with the TV and TV box communicating with each other. By switching on your TV first, then your box, it might fix the problem
  • It could be a problem with your TV or TV box. Try connecting using a different HDMI port on your TV. If this works, then it might be your TV port that's causing the problem. If it doesn't work, it could be a fault with your TV or your box
Try following these steps to fix this problem.
  1. Your HDMI setting on the box may be set to an output that your TV cannot support. Try pressing the following key combination to return to the menu.
    Press the Help button, then enter 7 2 0, then press OK.
  2. Check that your TV is on the correct input by pressing the 'Source' button on your TV remote control. This button usually has an icon like the one below and may also be labelled ‘Input’, ‘Mode', or 'AV'.
    Now scroll through the different input options until you reach the correct input channel. If you're not sure which input option to use, test each one.
  3. Check your picture quality alerts are on by going to
    Settings > TV Signal & Quality > Picture Quality Alert for Internet Channels.
  4. Make sure you're using the Hub we provided you with most recently, and not any other router or routing equipment.
  5. Check that your 4K recordable TV box is connected directly to your Hub with an Ethernet cable.
  6. Try changing the channel by pressing 1 on your remote, then return to BT Sport or Extra TV.
  7. Try restarting your Hub, modem, and 4K recordable TV box. Do this by disconnecting the power supplies. Wait 10 seconds, then reconnect the Hub and modem.
    When you have a solid broadband light on your Hub and modem, reconnect the 4K recordable TV box to the power supply. You'll know that your box has restarted when you see 'Hello' on the front panel followed by 'Please wait'. Try the channel again now.
  8. If the channel you were having trouble with was in Ultra HD or HD, you can also try tuning to the standard-definition equivalent.
  1. Your HDMI setting on the box may be set to an output your TV cannot support. Try pressing the following key combination to return to the menu.
  2. Verify that your TV is on the correct input by pressing the 'Source' button on your TV remote. This button usually has an icon like the one below and may also be labelled ‘Input’, ‘Mode', or 'AV'.
  3. Check your picture quality alerts are on by going to Settings > TV Signal & Quality > Picture Quality Alert for Internet Channels.
  6. Try changing the channel by pressing 1 on your remote control, then go back to the BT Sport or Extra TV channel.
If you can't perform a factory reset on your TV box using the buttons, you may need to try resetting using the menus.
Be aware that resetting your box this way deletes any recordings and scheduled recordings
If you experience any errors updating the software on your TV box, try the following:
  1. Give it one more go.
  2. If it doesn't work, check your box is connected to your Hub and the broadband's working, then try again.
  3. If possible, connect your TV box to your Hub using an Ethernet cable rather than mini-USB connectors. This provides a more reliable connection.
  4. If the update still fails, reset your EE TV box. Be aware that this deletes any recordings and scheduled recordings on your TV box.
Thanks for your feedback
Submit
