It's easy to manage your Hub's settings and get the best Wi-Fi setup. It's also easy to see the Hub Manager across all devices.
Open the Hub Manager
- Open a new web browser.
- Type 192.168.1.254 into the address bar.
- This will open the Hub Manager.
- If you want to make any changes to the hub settings, you'll need the admin password.
You'll find it on the back of the Hub if you haven't updated it.
Using the BT Hub Manager
Use the links to find out more about how you use the Hub Manager to change settings:
Smart Setup
What is Smart Setup on the BT Hub? How can I turn it on and off?
Hub lights
What do the lights on my BT Hub do?
Admin password
Where do I find the default admin password for my BT Hub?
How can I set up or change the admin password on my BT Hub?
Access control
How do I use BT access controls?
Wireless functions
What is the Wireless mode feature on my BT Smart Hub?
How do I see which of my BT Hub's wireless bands my device is connected to?
How do I turn wireless on and off on the BT Hub?
What is the Smart Wireless feature in my BT Hub?
I have problems connecting 5 GHz and dual-band devices wirelessly to the BT Hub
How do I split my BT Hub's SSID (wireless network name)?
Port forwarding
How do I set up port forwarding on my BT Hub?
Still need help?
For more advice on how to get the best from your BT Hub, visit Help for Hubs
Or, if you’ve got one of our older Hubs, why not buy our latest BT Smart Hub?
