Back
What is the wireless mode feature on my BT Smart Hub?
The BT Smart Hub lets you tune your wireless settings to deliver the best performance across all your devices. Your BT Smart Hub is automatically set to Mode 1.
Before changing modes, read the home Wi-Fi setup checklist.
The modes are:
  • Mode 1: Gives you the fullest featured wireless, maximising speed and range.
  • Mode 2: Some devices can sometimes struggle to use the latest wireless features. If you have any devices that can’t get a good wireless connection, try using this mode. Selecting this mode may reduce the wireless range and throughput but improve connectivity.
  • Mode 3: Change to this mode if your wireless devices don’t perform well using mode 1 or 2. Selecting this mode will reduce the latest features as well as wireless range and throughput compared to Mode 1 and 2. It'll enable the broadest range of devices to operate on the wireless. The features that are reduced include: power saving procedures, traffic aggregation methods and Multiple Concurrent data streams.
ModeBest forCompatible withAdvanced features
1Performanceg/n and a/n/acY
2Compatibilityb/n/g and a/nN
3Legacyb/g and aN
  1. Open a new web browser on a device connected to your Hub and type 192.168.1.254 in the address bar. This will open the Hub manager.
  2. Click Advanced Settings.
  3. Click Wireless.
  4. Enter the admin password. Unless you've previously changed it, you'll find the default password on your Hub settings card on the back of your Hub. If you have changed it and now forgotten it, you can use the password override feature to set up a new password without losing all your personal Hub settings and configuration.
  5. By default, your BT Smart Hub will be in Mode 1. To change mode, click on the Mode box and select the mode you want to use.
  6. Select the mode you want to use and click Set
  7. Remember, once you make any changes, you will need to save them. Click Save.
After changing the configuration settings, devices connected to your BT Smart Hub may lose connection. For devices connected via wireless, you may lose access to the BT Hub Manager pages. You'll need to reconnect using the instructions provided with each device.
This is not a feature on any of our older Hubs. To get the latest features and the best broadband experience at home, get our latest Hub from www.bt.com/smarthub.
Thanks for your feedback
Submit
