Here's a list of pages that can help you with common TV equipment problems.
Fix a problem
What can we help with?
TV equipment problems -
Remote control Having an issue with the remote for your EE TV box? Here's all the help you need. Just follow our simple step-by-step guide to quickly fix your problem.
TV box fixes Quick fixes if you're having issues, and how to reset your set top box.
TV channel or picture fixes Quick links to help if you're having issues with channels or the TV picture.
Problems with TV channels Run through some simple checks in turn. After each step, you should check your service to see if it's working.
Recording or sound Help if you're experiencing sound issues or recording issues with your TV Box Pro.
EE TV error codes Look up the error codes you may see on your EE TV service screen, and learn what they mean and how to resolve the issue.
EE TV app Choose the device you're using the EE TV app on to find a fix to your problem.
Powerline adapters Help if you're using a Powerline Adapter to connect your EE TV Box to the internet.
PIN help on EE TV Find out what the two different EE TV PINs are and how to change them.
Fix missing Freeview channels
Go back to: TV help
