If you need support with your EE TV box from BT, follow these helpful guides to troubleshoot the issue.
TV box fixes
Here are some answers to help you
I have a problem with my EE TV box -
How do I reset my EE TV box? How to perform a factory reset on your EE TV box from BT. You can do this using the buttons on the box or through the onscreen menus.
TV box gets hot If you find your TV set top box is getting too warm to the touch when operating, follow these simple steps to help keep it cool.
Go back to: What can we help with?
