Back
My TV box gets hot
If your TV box gets warm sometimes, don't worry - this is normal and perfectly safe. This can happen because the TV box has been designed without a cooling fan. If the box is stored correctly, it won't overheat. For added safety, the box has a heat detection chip inside so if it gets too warm, it'll automatically go into standby, and stay in standby, until the temperature is safe.
YouView box from BT
If you have the TV box pictured above and it gets warm sometimes, don't worry - this is normal and perfectly safe. This can happen because the TV box has been designed without a cooling fan. If the box is stored correctly, it won't overheat. For added safety, the box has a heat-detection chip, so if it gets too warm, it'll automatically enter standby and stay there until the temperature is safe.
To help keep the box cooler when you're not using it, we recommend turning on SMART Standby Mode:
  1. Press the Home button on your remote, then go to Settings.
  2. Go to Power & Standby.
  3. Select Standby Mode.
  4. Choose SMART (Recommended).
Storing your TV box correctly
  • Remove the protective film from the top of the TV box.
  • Make sure there's at least 5cm clearance above, and to the sides, of the box.
  • Don't put anything on top of it.
  • Don't put the box on top of any other electrical items.
  • Keep out of direct sunlight.
  • Keep away from other electrical devices or heat sources, such as external power packs.
  • Keep away from soft furnishings, such as cushions and rugs.
Thanks for your feedback
Submit
