Back
Fix missing Freeview channels on EE TV
Follow these steps to get your missing Freeview channels back on your TV box.
Before you start:
  • check that your TV aerial cable is plugged into the RF IN port on your TV box
  • make sure the cable is secure at both ends
Retune your channels:
  1. Press Home (or YouView) on your remote.
  2. Go to Settings.
  3. Select TV Channels.
  4. Choose Retune channels and press OK.
  5. Your channels should now appear.
If this doesn’t work
Check your aerial connection:
  • make sure the aerial cable is not loose or damaged
  • try reconnecting the cable firmly
Try another retune
  • repeat the steps above
  • wait until the scan fully completes
Still missing channels?
You may have a signal issue. If you need an aerial, we recommend a professional installation.
Our partner TSG can help: call 0844 247 0024 (Monday–Friday, 09:00–17:00).
Get more help
• Check your BT TV set-up guide
• Fix TV signal issues
• Contact the BT TV Helpdesk
Thanks for your feedback
Submit
