If you're having problems making or receiving calls, there are some quick, simple things you can check.
Phones bought before 2015 may not ring while connected to your Digital Voice Adapter. If you're experiencing this problem call us, and we'll supply a free microfilter that'll enable your phone to ring
If you're a new BT Digital Voice customer and your service hasn't worked, or if you need help setting it up, see How do I set up my service?
If your service has been working and now you're experiencing a problem, follow the steps below.
Note: If you have a Digital Voice handset and the screen has a triangle symbol, press the Help button on the phone for more information about the problem.
As your Digital Voice service uses broadband to work, the first thing to check is that your broadband is connected and working properly.
- Start by making sure you've connected your new Smart Hub. You can make sure everything is set up correctly by following the instructions in Connecting and setting up your BT Hub
- Next, check the light on the front of your BT Hub.
You should have a steady blue light. If not, it could indicate a problem with your broadband service.
Find out more about what the lights mean and what to do.Please note: The Smart Hub light turns purple when your broadband is down and you are connected to the EE mobile network via Hybrid Connect. When this happens, your Digital Voice service won't work. If you need to make an emergency call, you will need to use your mobile.
- If you have a steady blue light, check that you can access the internet by trying a web page using one of your connected devices.
If you can access the web page, please move on to step 2 - check handsets.
If you can't access the web page, have a look at BT Broadband connection problems
Now that you've checked your broadband connection is working, you need to make sure your handsets are working correctly.
Which handset are you using?
- Start by making sure your handset is switched on and has power. If your handset doesn't have power, go to I have a problem with my handset.
- Is there an error message on your handset screen (triangle symbol)?
Yes: press the Help button on the phone for more information about the problem or go to What does the message on my handset mean?
No: continue to the next step.- Does your handset screen show the message: "Register the handset"?
Please follow the steps on this Digital Voice setup page.
- Make sure you're in range of your Hub. If you're out of range, you'll see this message on your handset: "No link to Hub".
The handset will continue to search for a connection every 60 seconds until it finds one and you're back in range. You'll see a screen indicating it's searching for the Hub as it does so.
- Do you hear any announcements when trying to make a call?
Yes: turn off your Hub at the mains, then wait 1 minute before switching it back on. Wait for the Hub lights to settle and the connection to stabilise. If you're still hearing the message, go to What does the message on my handset mean?
No: please move on to step 3 - check settings and setup.
Other cordless handset
- Start by making sure your handset is switched on and has power. If it doesn't have power, please contact your handset manufacturer or refer to your user manual
- You can use an existing cordless handset with the Digital Voice service by connecting its base unit to the green phone socket on the back of the Hub. Check that the phone is plugged in correctly.
Corded phone
- Make sure your phone is plugged into the phone port on the back of the Hub
Yes: turn off your Hub at the mains and wait one minute before switching it back on. Wait for the Hub lights to settle and the connection to stablise. If you're still hearing the message, go to What does the message on my handset mean?
- Check the ringer volume settings on your handset.
- If you're using one of our Digital Voice handsets, check that the ringer hasn't been turned off. It is has, you'll see this symbol at the top of the screen:
Press the Vol+ button to turn the ringer volume up to the level you want.
If you're using a different handset or corded phone, please refer to your manufacturer's user guide for information on how to check the volume level. - Check if you've activated Call Barring
- If you're using one of our Digital Voice handsets, you can use your handset to check the status of Call Barring. From the main menu, navigate to the Calling Features option and select Call Barring.
Select the option to Check Status
If you're using a different handset, you can call *#34# or use the BT Calling Features menu, if your phone has one.
Alternatively you can log in using the My BT app and clicking the Manage Digital Voice section.
You can also check all your Calling and Network Features by logging into My BT.
This will allow you to see if you have activated any Calling or Network Features that may be stopping you making or receiving calls.
The Calling and Network Features portal within My BT will show you if you've activated Call Barring. If any of the options are set to ON you won't be able to make calls to those types of numbers. You can turn Call Barring off in the portal. - Check your Call Protect settings in the Calling and Network Features portal within My BT.
- You can also check things like your Blocked List in the Calling and Network Features portal to see if you've blocked certain numbers, or specific types of calls, such as international, from calling you.
You can also check and manage your Do Not Disturb service. If you don't want to be disturbed, this feature sends calls straight to voicemail between certain times, so could be the reason you're not receiving calls.
- Double check the number you're calling is correct. If it's saved in your phone's contact list, check it's right.
- If you're using one of our Digital Voice handsets, you can do this by clicking the Contacts button on your handset.
- If you have one connected, try making a call using another handset to check whether the problem is with the service or the handset itself.
- If you're using a corded phone, check that it's using tone dialing.
- Tone dialing uses different tones as you press each number. Some very old phones may have pulse dialing, which uses clicks, and may not be compatible with Digital Voice. There may be a switch on the phone base to select different types of dialing. If your phone has one, set it to DTMF dialing.
Fix your Digital Voice service with our troubleshooter
Report and fix your Digital Voice problem
If we can't find a fault or fix the problem online, we'll give you the option to book an engineer appointment.
If you can't connect to your BT Broadband, you can also do all of this using your mobile internet connection.
Already reported a fault?
Track your fault, change contact details and appointment times using our fault tracking service.
Still having problems?
Visit our contact pages for other ways to get in touch.
