Set up BT Broadband
Activation date
Check your activation date by logging into order tracker. Your broadband will go live any time up to midnight. You should receive an email or text from us when it's activated.
You’ll be sent a hub with everything you need to get started. Please be aware it won’t work properly until your broadband is live.
Return your old BT hub to avoid charges.
Engineer installating Fibre
Find out what to expect on the day of your engineer installation.
Using a Home Hub 3 or Home Hub 4 with fibre broadband? Follow these steps to get set up
Watch our experts
