Here's what to expect when our engineers come to your home to set up your broadband services.
Getting set up
What to expect when we set up your service -
How to set up broadband Set up your BT internet in 8 simple steps. Watch our short video guides or follow our step by step instructions. Learn more with BT help today.
What to expect in the first few days of broadband After your BT Broadband is first turned on, it can take about an hour to 'settle down'. During this settling-in period, you may experience an intermittent connection.
BT Smart Hub 3 Follow these simple steps to set up your BT Smart Hub 3 and Wi-Fi.
Connect your BT Hub - ADSL and Part-Fibre Learn why you should connect your BT Hub to the main socket, avoid extension leads and improve your broadband speed.
Set up Complete Wi-Fi To get the most out of Complete Wi-F (included with Halo 3+), you'll need a BT ID and the My BT app. Find out how to get set up.
BT Halo Learn more about your Broadband Backup and how to set up Complete Wi-Fi. BT Halo customers can also get a Mini Hub if you lose your connection.
Home networks Whether you have a Wi-Fi or wired network in your home, here is the help and support you need.
User guides and manuals User guides, manuals and regulatory information for BT Hubs and Wi-Fi Extenders.
Home Tech Experts If you’re having a BT technical issue or there’s a fault in your service, our Home Tech Experts can help with a home or contactless visit.
Set up broadband microfilters This article covers microfilters, which allow broadband to work while your phone service remains active.
Home wiring and broadband set-up Set up your broadband and home wiring for the best performance.
Has my BT Broadband been activated? How to check if your new broadband service has been activated and is ready to use.
WPS to connect my devices Yes, on the rear of the case, press the WPS Wi-Fi setup button for about 1 second
Go back to: Broadband help
