If your Digital Voice service stops working, try these quick, simple checks to get everything back up and running.
Fix a problem with your Digital Voice service
Common fixes -
Unable to make or receive calls Quick help if you're unable to make or receive calls using your Digital Voice service.
Problems with a burglar alarm or health pendant Help if you're having issues with your burglar alarm or telecare devices after moving to the Digital Voice service.
Problems with my calls Step-by-step advice for resolving call quality issues with your Digital Voice service.
Problems with my handset Simple solutions for common issues with your Digital Voice handset.
Problems with my service Answers to the most common issues you may have with the Digital Voice service, including making and receiving calls, problems with your phone or extensions.
What does this message mean? If you're seeing or hearing a message, here are some quick, simple checks to help you understand what it means and what you need to do next.
My extensions have stopped working Fix issues with home phone extensions, burglar alarms or health pendants after moving to Digital Voice.
Problems with Battery Back Up Your Battery Backup (BBU) provides at least an hour of broadband service if there's a power cut. Learn how to troubleshoot if you have a problem with it.
Broadband connection problems If broadband connection issues are affecting your Digital Voice service, here are some steps to diagnose and resolve them.
