Back
All about Call Diversion
The UK’s ageing and unreliable copper landline network is being retired.
When BT contacts you, take action to avoid disruption to your home phone or broadband services
Further information and support are available on our Connected Together website, or by calling 0330 1234 150.
Call Diversion lets you divert your calls to almost any phone, including your mobile. Call Diversion can also divert calls while your phone line is in use.
To use Call Diversion, you'll need a touch-tone phone switched to tone dialling. Most modern phones have this feature.
Digital Voice handsets allow direct access to this feature, so you can divert your calls to your mobile when you are going out for the day or on holiday.
The Call Diversion service can also be switched on by pressing the star (*) and (# )keys on other handsets connected directly to your Hub.
How much does it cost?
The Call Diversion service is inclusive for Digital Voice customers.
Calls are diverted to a BT Mobile or BT Home Phone. If you have a call plan with inclusive minutes, these calls will be free.
Calls diverted to a BT mobile or BT home phone service are free.
Calls to any other service will be charged at the standard rate for calls to that service. If these calls are available in any inclusive call package, they will be included in that package.
For our latest prices, please go to the BT Residential Phone Tariff; (PDF).
Cost of the calls
You’ll be charged for the duration of any diverted calls, plus the standard call setup fee. The Call Diversion cost per minute will be the same as when you make a call from your home phone (outside your calling plan's inclusive minutes).
The cost of a diversion will depend on:
  • the duration of the diverted call
  • the type of number you're diverting to.
    (Diverting to a mobile number will cost more than a home phone)
How to get Call Diversion
For Digital Voice and Home Phone Standard customers, Call Diversion is already included with your Home Phone service.
For Digital Voice customers, you can manage your features at add or remove Calling Features online.
Using Call Diversion
To divert your calls, follow these instructions using the home phone line you want to divert calls from (touch-tone phone required):
Divert all calls
  1. Dial *21* (star, 2, 1, star).
  2. Enter the phone number you want to divert to.
  3. Press # (hash key).
An announcement will tell you that you've successfully set up the diversion.
Divert any calls you don't manage to answer within 15 seconds
  1. Dial *61* (star, 6, 1, star).
Divert calls when your phone is engaged
  1. Dial *67* (star, 6, 7, star).
An announcement will tell you that you've set it up successfully.
Divert calls using a Digital Voice handset
  1. From the voice menu, first select the Calling Features options.
  2. Select Call Diversion.
  3. Select Set Up.
  4. Enter the number you would like to divert calls to.
  5. Select Set Up to complete the process.
How to check which numbers you're diverting calls to
To check the diverts you've set up on your line, follow these instructions:
  • To check the number you've set up for divert all calls: *#21# (star, hash key, 2, 1, hash key)
  • To check the number you've set up for calls you don't manage to answer within 15 seconds: *#61# (star, hash key, 6, 1, hash key)
  • To check the number you've set up when your phone is engaged: *#67# (star, hash key, 6, 7, hash key)
Using Call Diversion and Call Barring together
If you've got Call Barring and want to use it with Call Diversion, you must switch Call Diversion on first.
Switching off Call Diversion
To switch off Call Diversion:
  • Switch off "divert all calls" dial: #21# (hash, 2, 1, hash)
  • Switch off a diversion you've set up for calls you don't manage to answer within 15 seconds, dial: #61# (hash, 6, 1, hash)
  • Switch off a diversion you've set up when your phone is engaged dial: #67# (hash, 6, 7, hash)
Thanks for your feedback
Submit
