Back
About Hybrid Connect
This page offers information and help needed for your Hybrid Connect.
Hybrid Connect, a black rectangular device with the EE logo on the front.
What's in the box?
Image of Hybrid Connect
Your Hybrid Connect
Power supply. A 3-PIN UK plug, rectanglular shaped with a cable and power connector at the end.
Power Supply
Image of paper user guide.
User Guide
Cable with identical rectangle ethernet connector at each end.
Ethernet cable
What the Hybrid Connect looks like
Connectors, ports and buttons on the rear of the Hybrid Connect.
Image of back of the Hybrid Connect device zoomed-in on the ports and connectors. Description of each port follows.
Round push button.
Wireless (WPS) button
To pair with your Smart Hub.
Roud screw type connector.
Antenna port
Optional for antenna to be connected.
Single ethernet port.
Ethernet (1 port)
For optional wired connection to Smart Hub.
A small round hole. The power supply cable plugs into it.
Power Connector
Small pinhole button.
Reset button
Rest to factory default settings.
Round push button.
Power button
Set up instructions
Once you've checked that you have everything in your box, you can begin the set up.
A QR code that once scanned will redirect your mobile to the BT app.
Scan this QR code on your device for further support setting up your Hybrid Connect device.
Error states
Not sure what the lights on your hub mean? Find out what they're telling you and how to resolve them.
Disposing of your electrical equipment
To help protect the environment, the UK Government requires that electrical and electronic equipment is not disposed of with general household waste. Instead, it should be collected separately and handled in an environmentally responsible way.
a line drawing of a wheelie bin with a large cross drawn over it.
The symbol shown here and on a product means you shouldn't have to throw it your normal rubbish bin at the end of its working life.
This product may contain substances that could be harmful to people or the environment if it’s not recycled correctly. The equipment provided to you will remain the property of BT at all times (excluding outright sale equipment). You’ll need to return it back to us within 60 days of telling us you want to cancel, or we may need to charge you for it. You can do this by following the steps here: How to return and recycle your BT equipment.
As the environment is important to BT, we can get rid of it in an environmentally friendly way.
If this equipment is a replacement for something similar, then you can also dispose of your old kit by following the instructions above.
Saftey notice and care instructions
Important safety and care instructions
Your Hybrid Connect from BT is manufactured to comply with European safety standards. Please read the following instructions carefully before installing and using it.
Installation and location
  • For indoor use only in UK.
  • Position all parts, including power adapters away from heat and sun (e.g. away from radiators, window sill or other electrical equipment which can get hot).
  • Keep area ventilated (e.g. don’t put in cupboards or back of sofas) and don’t block any vents with objects or thick carpets.
  • Keep device and cables out of young children’s reach.
  • Only use power adapters provided for this specific device; see the Help section at the back of this user guide for further information online or to contact our helpdesk if you need a replacement.
  • Electronic devices hate liquids; don’t place devices and power adapters in damp areas or near sources of water or splashes.
  • This device uses wireless technology; check before using or installing where restrictions may apply such as in hospitals.
  • Product may cause scratches or marks if placed on fragile surfaces (e.g. veneered wood or delicate fabrics); place on a mat if required.
  • Don’t use near flammable substances or in a flammable atmosphere (e.g. warehouse or garage).
  • Designed for use at room temperatures between 0 and 40°C.
  • Keep device flat/upright on its feet/stand at all times. Not standing it as designed could cause overheating.
Care and maintenance
  • Treat all parts with care; no shock or vibration, and don’t pull, twist any cables.
  • Regularly check your product for damage to ensure small parts aren’t exposed.
  • Dust with a soft dry cloth; don’t use water or solvent.
  • Regularly check that objects don’t cover any parts or any vents that could cause overheating.
  • When not in use, store in a dry place and away from extreme heat or cold.
Warnings
  • If your devices or power adapters appear damaged, stop using them immediately. Switch off your electrical socket if it’s safe to do so and contact our helpdesk.
  • Don’t try to open your devices or power adapters. There are no serviceable parts and you risk an electrical shock.
  • This device has been evaluated for and shown compliance with European Guidelines when installed and operated with a minimum distance of 20cm between the unit and your body.
  • There is a slight chance your product could be damaged by an electrical storm. We recommend that you unplug the power and phone line cord during a storm.
  • If you’ve got a pacemaker please check with your doctor before installation.
Compliance information
Radio Equipment Directive Declaration of Conformity
EU
Hereby, BT declares that the radio equipment type Hybrid Connect (LRDD6391BF11-SA) is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available.
Hereby, BT declares that the radio equipment type Hybrid Connect (LRDD6391BF11-SA) is in compliance with Radio Equipment Regulations 2017 and The Product Security and Telecommunications Infrastructure (Security Requirements for Relevant Connected products) Regulations 2023. The full text of the EU declaration of conformity.
Restrictions
This radio equipment is subject to certain restrictions when it is placed on the market in Belgium (BE), Bulgaria (BG), Czech Republic (CZ), Denmark (DK), Germany (DE), Estonia (EE), Ireland (IE), Greece (EL), Spain (ES), France (FR), Croatia (HR), Italy (IT), Cyprus (CY), Latvia (LV), Lithuania (LT), Luxembourg (LU), Hungary (HU), Malta (MT), Netherlands (NL), Austria (AT), Poland (PL), Portugal (PT), Romania (RO), Slovenia (SI), Slovakia (SK), Finland (FI), Sweden (SE), Northern Ireland (UK(NI)), Norway (NO), Switzerland (CH), Iceland (IS), Turkey (TR), Lichtenstein (LI).
This radio equipment is also subject to certain restrictions when it is placed on the market in United Kingdom (UK):
In accordance with the relevant statutory requirements in the UK, the 5150 to 5350 MHz frequency range is restricted to indoor use in the United Kingdom.
This device can only be used in the UK as it may use frequencies in the 5.725-5.850GHz band which are not allowed elsewhere in Europe.
Radio Transmission Information
5.15-5.35
Max power in the range
200mW
5.5-5.7
1W
5.725-5.85
200mW
LTE Bands 1/3/7/20/38
<23 dBM
Frequency range (GHZ)
5.15-5.35
200mW
5.5-5.7
1W
5.725-5.85
200mW
<23 dBM
Power Information
The device Hybrid Connect (LRDD6391BF11-SA) complies with EN 62368-1. The rating label is located on the base of the device.
PSTI and Software Support
To find the support period for your device or to report security issues, go to: bt.com/terms/otherlegalstuff
The BT WiFi Disc contains code that is covered by the GNU General Public License (GPL). In accordance with the GPL, EE has made the relevant code available for download at: bt.com/help/gplcode
Other support information
WiFi standard
WiFi 5
Wireless capability
5GHz
Wired connections
1 x 1Gbps LAN​
Supported LTE Bands
1/3/7/20/38
Supported broadband technology
Full Fibre
Part Fibre
ADSL
Contactless WiFi pairing
Yes – To Hub
Parental Controls and Security
Yes – Hub/Broadband controlled
Smart Hub Compatibility
Yes - BT & EE Smart Hubs
Sustainability
Plastic-free packaging​
Recycled casing
WiFi standard
WiFi 5
Wireless capability
5GHz
Wired connections
1 x 1Gbps LAN​
Supported LTE Bands
1/3/7/20/38
Full Fibre
Part Fibre
ADSL
Yes – To Hub
Sustainability
Recycled casing
More accessibility information
BT's Here for You section has further information about Getting the most from your devices
Full user Guide
Hybrid Connect user guide PDF
Thanks for your feedback
Submit
