Back
Do I need to use the BT Hub for EE TV?
Subscription TV channels come over your broadband connection rather than your TV aerial, so you must have a reliable broadband connection.
To watch your subscribed channels, you need to use the BT Hub that we sent you. If you're not using the correct Hub, you may see an error message.
You can check what type of BT Hub you have by checking the label on the back or bottom of the Hub. Or see: Help for BT Hubs.
Other routers or older Hubs aren't supported.
Thanks for your feedback
Submit
