Back
Problems logging in to the EE TV App and online player
BT TV is now EE TV. You'll still get all the same entertainment and sport you know and love. Find out what EE TV has to offer.
If you’re having any problems logging in to the EE TV App or online player, this guidance should help.
Check your BT ID login is set up
Your BT ID is the username and password you’ll need to access the EE TV App.
Once your BT ID username and password are set up, follow the steps below.
Check your EE TV account is linked to your BT ID
  1. Log into My BT
  2. Get your EE TV account number. You can find this in the top right-hand corner of your bill. It consists of two letters and eight numbers, for example GB12345678
  3. Click on the 'All Product' arrow on the right-hand side of your screen
  4. If your TV account is shown here, then your BT ID is linked to it
  5. If your BT ID isn’t linked to your TV account, you can do that by using your BT ID to login here > and following the steps to link it
Check your BT ID account role is listed as Account holder
  1. Log into My BT
  2. Click on Settings, then Account, and you’ll see the 'Account role' status
  3. If your account role is 'Account holder', then you should be able to log in to the EE TV App
  4. If your account role is 'Account manager', you won’t be able to log in to the EE TV App and you can either:
  • Change your 'Account role' to 'Account holder' by clicking on I should be the account holder and following the steps
  • Important: You should only change the 'Account role' if you're responsible for paying the bills on this account.
  • Use the BT ID of the 'Account holder'
Thanks for your feedback
Submit
Need more help?
