Back
Sign language on your TV box
This article helps you determine if a programme on EE TV supports British Sign Language and how to use that feature.
British Sign Language (BSL) is a language which, rather than using sound, uses hand-shapes and patterns together with facial expressions to communicate and express feelings.
Find out if a programme has sign language available
Not all programmes support this feature; it all depends on whether the broadcaster has made it available.
You can find out if a programme has sign language by viewing the programme summary:
  • With the programme on your TV.
  • Press the i button on your remote.
  • If the programme summary shows [SL], it has sign language available.
Turn on sign language
You can turn this feature on by:
  1. Pressing the Home button on your remote.
  2. Go to Settings.
  3. Select Accessibility & Language.
  4. Select Language & Subtitles.
  5. Select your preferred setting.
  6. Select Done.
Enabling this feature means that if a signed version of On Demand content is available, you'll be delivered the signed version of the programme.
We’re committed to providing the best support possible to all our customers, whatever their situation. Find out more on our Here For You pages.
Thanks for your feedback
Submit
