If you find using the TV remote control difficult, a plug-in UK USB keyboard can be used instead. Keyboard key mapping is used to support popular accessible keyboards.
This currently works with the keyboards below. Click on the keyboard you use to see which keys replicate your remote control buttons:
The keyboard can be used in conjunction with the remote control, or as a substitute. This works across the YouView menus, including the On Demand players.
