Back
All about Call Barring
What is Call Barring?
Call Barring lets you stop certain types of calls being made from your phone. You can also use it to bar all incoming calls.
How much does it cost?
The monthly cost depends on how many calling features you have from those offered in the Calling Feature Pack. A 30-day minimum term applies. You can check all prices in the Home Price Tariff Guide (PDF).
Line Rental Plus customers can choose to opt in to take the Calling Feature Pack at no extra cost. They can also choose to opt in to International and Premium Rate Call Barring at no extra cost.
Activate your Line Rental Plus call barring now >
How do I get it?
You can easily add or remove Calling Features online >
How do I use Call Barring?
Our Calling Features guide tells you how to use it.
BT Calling Features user guide (PDF doc, 170KB)
You will need Adobe Reader to view PDF documents.
Thanks for your feedback
Submit
