Back
Change or cancel your BT phone, TV or broadband package
Change your BT package
Step 1: Check your current package
  1. Log in to My BT.
  2. View your current services and contract details.
Step 2: Choose a new package
You can:
  • Upgrade your broadband speed.
  • Add or remove TV packages.
  • Change your phone plan.
Step 3: Make the change
If you can’t change your package online
  • Check you’re logged into the correct account.
  • Try again later.
  • If it still doesn’t work, contact us.
Cancel your BT package
Step 1: Check your contract
Before cancelling, check:
  • Your minimum term.
  • Any early exit charges.
Step 2: Contact us to cancel
You’ll usually need to speak to us to cancel your service.
We’ll:
  • Confirm your cancellation date.
  • Explain any final charges.
  • Help you with next steps.
What happens after you cancel
  • Your service will stop on the agreed date.
  • You may need to return equipment.
  • You’ll receive a final bill.
If you’re moving to another provider:
  • In some cases, your new provider can manage the switch.
  • Check with them before cancelling.
Fix common problems
I can’t access My BT
  1. Reset your password.
  2. Check your login details.
I’m not sure about the charges
  • Contact us before making changes.
  • We’ll explain any costs.
I changed my mind
  • Check your cooling-off period.
  • Contact us as soon as possible.
Need more help?
  • Manage your account in My BT.
  • Contact us for support with account changes.
  • Get help choosing a new package.
Accessibility and additional support
If you need extra help:
  • Ask for information in accessible formats.
  • Use Relay UK if needed.
  • Add an authorised person to manage your account.
Thanks for your feedback
Submit
