Back
Aerial and Internet Modes on EE TV
Learn the difference between aerial and internet modes on EE TV, including benefits, recording options, and how to switch between modes.
Internet mode streams TV over your broadband, so you don’t need an aerial. Picture quality depends on your internet speed, and some features (like BBC recordings) play through apps such as iPlayer.
Aerial mode uses a traditional TV aerial, so picture quality depends on signal strength. It gives you access to the full range of Freeview channels and supports more simultaneous recordings.
The TV Box Pro is the only box that lets you watch your favourite shows in two ways. Either over the internet or using an aerial, whichever works best for you. To make sure you get the best experience from EE TV, here’s all you need to know about the differences between the two modes.
Internet Mode
This is available for the TV Box Pro, TV Box Edge and Apple 4K. TV picture quality relies on your broadband speed. You must have a Smart Hub within 5 metres of your TV box if connecting via Wi-Fi.
Benefits
  • The TV Box Pro allows two recordings at the same time.
  • The most popular free-to-air channels are available. Find out more on our free-to-air channel guide page.
  • There’s no need for an aerial.
Recording BBC programmes in Internet Mode
BBC programmes that you record in Internet Mode will play automatically from the BBC iPlayer app. This means you’ll always get your full recording (even if you set it up after the programme has started) in the highest quality. Finding programmes you love will also be easier, as iPlayer has features such as ‘more like this’ and the ability to show you previous or future episodes of what you have recorded.
Before you start recording:
Skipping ITV adverts in Internet Mode
When watching live and recorded ITV shows in internet mode, you can no longer skip the adverts, just like the ITVX app. You’ll still be able to pause, fast-forward, and rewind ITV shows, but you won't be able to fast-forward through the adverts. An ITVX Premium subscription is ad-free for on-demand content, but it won't let you skip adverts on live TV or recordings.
Channels missing in Internet Mode?
The most popular free-to-air channels are available. However, you’ll notice U (previously known as UK TV), + 1 and the Radio and Music Channels are not on our free-to-air channel guide page.  You can still access these programmes using that channel’s app, which can be found in the Main Menu.
Aerial Mode
This is the recommended option for customers with broadband speeds below 22 Mbps. To find out how to test your broadband speed, visit our Broadband speed help pages.
In aerial mode, picture quality depends on the aerial's signal strength. You must have a working aerial. If you need help ordering and installing an aerial, visit our aerial help pages.
Benefits
  • Up to 4 recordings at the same time.
  • Access to the full selection of Freeview channels available at your address.
Check which TV mode you're using
There are two ways to find out which mode you’re in:
  1. Check whether you have an aerial plugged in; see EE’s Getting Started Guide to find where your aerial should be installed.
  2. If you can’t reach the back of your box, check which mode you’re in by going to Settings from the Main Menu and selecting TV Channels. If there’s an option to retune the channels, then you’re in Aerial Mode.
How to switch modes
Switching requires a reset, which deletes your existing recordings and logs you out of all your apps.
If you're switching to aerial mode, plug in your aerial. If you're switching to internet mode, unplug your aerial.
To go ahead with the switch:
  1. Go to the main menu by pressing the Home button on your remote.
  2. Select Settings.
  3. Go to Information and Reset, then select Factory Reset.
  4. You will see a warning that your recordings and information will be deleted. See the steps below if you want to keep your recordings and switch modes.
  5. If you wish to continue, enter the numbers shown on screen, using your remote.
  6. Follow the setup process. When prompted to select the TV Channels Mode, choose either Stream TV Channels from the internet or Stream TV Channels from an Aerial.
Doing a full reset but keeping your recordings, series links and reminders
  1. Go into Maintenance Mode by pressing and holding the down arrow on top of the TV Box; after 5 seconds, the message “Enter Maintenance Mode Y/N” will appear on your TV screen.
  2. Press the power button. After a few seconds, a Maintenance Mode menu will appear on screen.
  3. Select Factory Reset; recordings, Series Links, and Reminders WILL be kept.
Thanks for your feedback
Submit
