The discovery+ app is not supported on some older BT TV boxes. This article explains which TV boxes are affected, how to upgrade your device, and alternative ways to keep watching discovery+ without interruption.
What you need to do
If your BT TV box no longer supports discovery+ and you want to keep watching, you’ll need to upgrade to a newer box to continue watching on your TV. Your discovery+ subscription won’t be affected, and you can continue to watch on supported devices.
To upgrade your TV box, call us on 0800 800 150, and we’ll guide you through the process.
If you’ve been asked to return your old TV box once you’ve upgraded, you can find return instructions on this page: BT return and recycle.
You should know
Recordings won’t transfer if you upgrade your BT TV box: Any shows or movies saved on your current box won’t be available on your new one.
You can still watch TNT Sports: Even if discovery+ is no longer supported on your box, you’ll still be able to watch TNT Sports channels through the BT TV guide.
Other ways to watch discovery+: You can still use the app on devices such as smart TVs, tablets, laptops, and smartphones. For a full list of supported devices, visit this discovery+ support page.
Which BT TV boxes are affected?
The following boxes no longer support the discovery+ app:
4K Recordable TV Box
TV Box
Recordable TV Box
To learn more about BT TV boxes, visit About BT TV boxes.
