Channels leaving BT TV in 2021
From spring 2021, a few channels won’t be in non-flexible BT TV packages anymore.
Some of these won’t be in any of our packages going forward, others will only be in flexible TV packages.
Channel |
Removed on |
Recordings lost on |
Available in flexible packages |
Sky History |
1 March 2021 |
31 March |
Yes |
Sky History 2 |
1 March 2021 |
31 March |
No |
Crime and Investigation |
1 March 2021 |
31 March |
No |
Lifetime |
1 March 2021 |
31 March |
No |
SyFy |
1 April 2021 |
4 May |
Yes |
E! |
1 April 2021 |
4 May |
No |
Is there any way to keep a channel I like?
If you want to keep a channel that's in our flexible packages (shown in the table above), you can. Just switch to a flexible TV package.
If not, you might want to take a look at our flexible packages anyway. You'll probably find a different channel with similar shows.
Can I still watch my recordings?
After a channel ends, you'll have a few weeks to watch the shows you recorded from that channel. Make sure you catch them before they're gone (dates shown in the table above).
