Back
Get started with BT Mobile
  • Keep your number
    Follow these easy steps to keep your mobile number when moving to BT Mobile.
  • Set up voicemail
    Find out how to set up and use your mobile voicemail to ensure you never miss an important call, including setting up a voicemail PIN so you can access your messages from any phone.
  • Manually set up data for Android mobiles
    Most phones automatically set up when you insert a BT Mobile SIM. If mobile data or picture messages (MMS) aren't working, you can fix this by manually configuring the settings.
  • Parental Controls
    Protect your family online with BT Mobile parental controls. Block harmful content, set filter levels, and keep children safe while browsing.
  • 5G on BT
    Find out what phone and plan you need to use BT 5G. Check device compatibility, coverage requirements and how to get started with faster mobile speeds.
  • 4G on BT
    Explore the benefits of a 4G mobile connection and check coverage for your area.
  • About Wi-Fi Calling
    Make calls and send texts over Wi‑Fi with BT Mobile. Ideal for poor signal areas, works in the background, uses your plan allowance, and needs no app.
