Back
Report and track your BT problem
Choose your product and log in to our troubleshooter to report your problem.  Our troubleshooter will run tests to identify the cause of the problem and explain how to fix it.
If the problem can’t be fixed online you'll be able to arrange an engineer visit.
New Broadband customer?
Your broadband speed can vary for the first 10 days after connection as your line adjusts. Use our troubleshooter if you’re experiencing slow speed after this time.
Learn more about connecting to broadband
Track fault
Check the progress of your reported problem.
Track Broadband Fault
Track Landline Fault
Track mobile repair
Check the progress of your mobile repair.
Track repair
