Back
Do I need a special faceplate for Fibre?
There are two types of fibre-based broadband:
  • Where the fibre cable goes to the street cabinet, with a copper cable from there to your home. This is known as Fibre to the Cabinet (FTTC) or Part-Fibre.
  • Where the fibre cable goes all the way to your home. This is known as Fibre to the Home (FTTH) or Full Fibre. You don't need a special faceplate for this type of broadband, so you won't have one installed.
If you're setting up Fibre yourself
If you're setting up your Fibre, you don't need a special faceplate. We'll send you microfilters to use with your existing socket. However, you don't need to worry about microfilters if your primary socket already has a broadband accelerator faceplate fitted (a primary socket with two sockets).
If an engineer is setting up your Fibre
We'll fit a special faceplate to the front of your primary phone socket when we install Fibre. It helps you achieve the fastest speeds by separating the broadband signal from interference caused by your home's telephone extension wiring and the devices connected to it.
We'll also remove any microfilters you have plugged into phone sockets, as you don’t need them for Fibre. We recommend you keep your old microfilters somewhere, though, just in case you need them again.
How do I know if I need an engineer for my Fibre Broadband?
In some cases, an engineer will need to visit your home to optimise your telephone line for Fibre Broadband. This will depend on the product you order and the telephone line at your home. We'll let you know when you place your order if we need to send an engineer and book an appointment for you.
If you do need an engineer to get Fibre Broadband, we won't charge you anything extra.
Thanks for your feedback
Submit
Need more help?
