Back
How do I set up Complete Wi-Fi?
You can quickly set up BT Complete Wi-Fi using the My BT app and your Wi-Fi Discs. Follow these simple steps to boost your signal and get more reliable Wi-Fi across your home.
You can set up BT Complete Wi-Fi in three different ways. The My BT app is the easiest option, but you can also connect your Wi-Fi Disc using an Ethernet cable or using the WPS button.
Choose the option that works best for you and follow the steps below.
Choose how you want to set up your Wi-Fi Disc
Set up using the My BT app (recommended)
  1. Log in to the My BT app
  2. Select Set up new disc
  3. Follow the on-screen instructions
Set up using an Ethernet cable
  1. Plug the Ethernet cable into your hub and Wi-Fi Disc
  2. Wait for the light to turn solid blue
  3. Unplug the cable
  4. You can now move the disc to improve coverage
Set up using WPS
  1. Plug your disc in near your hub
  2. Press the WPS button on your hub
  3. Press the WPS button on your disc within 2 minutes
  4. Wait for a solid blue light
  5. You can now move the disc to improve coverage
Where to place your Wi-Fi Disc
  • Place it halfway between your hub and weak signal areas
  • Keep it out in the open
  • Use the My BT app to check signal and adjust placement
Check your Wi-Fi is working
Don't forget, you can use the My BT app at any time to check performance and manage your network.
If you're still having problems with Wi-Fi or your connection in general, use our online troubleshooter.
Thanks for your feedback
Submit
