If you're new to BT Broadband and setting up your broadband connection for the first time, we strongly recommend you follow the instructions that came with your Hub.
Download broadband setup guides for your Hub >
If you've already set up your broadband connection and would now like to connect another computer using Ethernet, follow these steps:
What you need:
- A spare Ethernet port on your computer
- A spare Ethernet port on your BT Hub
- An Ethernet cable
An Ethernet cable is generally yellow or white with yellow ends. The connector looks like this:
The Ethernet port is normally marked LAN and will connect with the ports on the back of your Hub:
Setting up
- Plug one end of the Ethernet cable into your computer, and the other into the Hub or router. Make sure the connections are fully pushed in - you'll hear a click as they lock into place
- Wait for a moment until you see an Ethernet icon on your computer. This will mean you're connected.
If you can't see the icon, check that there are flashing green lights where the cable goes into your computer
If you're having trouble connecting to the internet, make sure the Hub's main light is blue. If you're seeing any other lights or colours, please review What do the lights on my BT Hub do?
If you've manually changed your network settings (like your IP address or DNS server) in the past then you might need to change these settings back to automatic for your BT Hub to connect successfully.
Still need help?
For more advice on how to get the best from your BT Hub, visit Help for Hubs >
Or, if you’ve got one of our older Hubs why not buy our latest BT Smart Hub? >
