Back
If there's a number you don’t recognise on your BT bill
Step 1: Check the number
Look at the full number and call details on your bill:
  • date and time of the call
  • call duration
  • cost
This can help you identify the call.
Step 2: Check with people who use your phone or account
Ask anyone who may have used your phone, such as:
  • family members
  • friends
  • visitors
Some calls may have been made without you realising.
Step 3: Check common reasons for unknown numbers
The number may be:
  • a service or customer support line
  • an automated call (such as voicemail or call divert)
  • a premium-rate or international number
  • a number is stored differently in your contacts
Step 4: Check your call settings
Check if any features are active:
If you still don’t recognise the number
Contact us, and we’ll help you check the charge.
Please give us:
  1. the number.
  2. The date and time.
  3. The charge on your bill.
If you think the charge is wrong
  • contact us as soon as possible
  • we’ll investigate and explain the charge
You can get more detailed information about calling prices from a BT line in the BT Tariff Guide (PDF).
Use this table to help you recognise a number from your bill:
NumberUse
00Access for international calls
01National geographic numbers in the UK
02National geographic numbers in the UK
03National non-geographic numbers with calls charged at or below rates for geographic numbers
04Not used
0500Numbers that are free to call
055Corporate numbers
056Location Independent Electronic Communications – typically VoIP services
06Not used
070Personal numbers
076Radio paging calling
071-075 & 077-079Mobile telephones
0800 & 0808National numbers that are free to call
0820National numbers for Internet for school services
0844Service numbers that consist of an access charge from BT, plus a service charge set by the company you call
0845Service numbers that consist of an access charge from BT, plus a service charge set by the company you call
0870Service numbers that consist of an access charge from BT, plus a service charge set by the company you call
0871 & 0872Service numbers that consist of an access charge from BT, plus a service charge set by the company you call
090, 091 & 098Premium Rate Services. Service numbers that consist of an access charge from BT, plus a service charge set by the company you call
100Operator
112Emergency assistance
118xxxDirectory Enquiries. Service numbers that consist of an access charge from BT, plus a service charge set by the company you call
141Dialling 141 before you dial a number means that your number will be withheld. This service is called blocking your calling line identity (CLI)
2-8Not used in the National Number Plan, but may be used for local dialling to geographic numbers and as ‘short codes’ from mobile telephones
999Emergency assistance
Thanks for your feedback
Submit
