Back
Can I use a different type of BT cordless phone with my existing base?
To find out if you can use a different type of BT cordless phone with your base, you need to know if it is GAP compatible. To check, go to the user guide for your phone. If your phone is not GAP compatible, you can only use extra phones that are the same model. If your phone is GAP compatible.......
To find out if you can use a different type of BT cordless phone with your base, you need to know if it is Generic Access Protocol (GAP) compatible. To check, go to the user guide for your phone
GAP-compatible means a phone is designed to work with other Digital Enhanced Cordless Telecommunications (DECT) devices, regardless of manufacturer.
  • You can only use extra phones that are the same model and make as your base
  • You should be able to register your phone to the base but it is not guaranteed that all features will work.
  • Phones that are GAP compatible are only required to:
    • make and receive calls
    • ring for incoming internal, external and paging calls.
  • In most cases, the phone will show Caller Display information but it is not mandatory.
There is also a limit to the number of phones that you can register to a base.
For more information, see the user guide for your phone
Thanks for your feedback
Submit
