If you need to reset the discs to factory default settings you can do this using the pin hole on the back of each disc:
- First, make sure the discs are switched on
- On each disc press the Reset button (on the rear of the disc) for one second. Wait a couple of minutes to reboot
- If everything’s OK, the LED will turn purple, flashing blue and then solid blue. Please also see the disc’s LED settings card on the rear for default factory settings
- Your network name and admin password will revert back to what is shown on the back of the disc
