Back
Does Whole Home Wi-Fi present all disc APs as a single network to the client?
All discs (APs) for 2.4GHz and 5GHz use the same Network name (SSID), so most clients will see it as a single network. A small handful of clients will list the discs separately as the discs have different BSSID/MAC address.
This also applies if you turn on the Guest Network, when the same Guest Network name (SSID) will be used for both 2.4GHz and 5GHz.
Thanks for your feedback
Submit
Need more help?
