Back
How do I manually update software on EE TV boxes?
You can check if a software update is available manually at any time by going to:
  1. Settings.
  2. Software Information.
  3. Update software.
  • Or:
  1. Settings.
  3. Update players and apps.
If an update is available, your TV box will then download it automatically.
However, your TV box will update its software automatically on a regular basis if it’s connected to the internet. To receive automatic software updates, leave your box in standby and your Hub connected.
Thanks for your feedback
Submit
