Back
What if I go over my BT Mobile data or call allowance?
If you go over your data and call allowance it can get quite expensive. Maybe consider upgrading your plan or ordering an add-on to tide you over.
If you go over your data and call allowance, it can get quite expensive. Maybe consider upgrading your plan or ordering an add-on to tide you over.
Going over your allowance will cost:
  • Data - 15.52p per MB
  • Calls - 54.37p a minute to any UK mobile or standard UK fixed-line number 01, 02, 03. There's a one minute minimum call charge, then you pay by the second
  • Texts - 15p per message
Upgrading your plan
If you’re using up your entire allowance each month, you can upgrade your plan to get extra data or minutes.
Upgrade your plan now
Add extra data and minutes
If you don’t want to move up a plan but need extra data and minutes as a temporary measure, you can order one of our add-ons via My BT. Once your usage is back to normal you can cancel it.
Order extra data and minutes now
When will my allowance reset and how can I check my usage?
Our My BT app is the easiest way to keep an eye on your usage. It will also tell you when your monthly allowance resets.
You can find it on Google Play, in the iPhone App Store or Windows Phone Store. Just search for "My BT".
Or, you can check your usage and manage your account at www.bt.com/mybt.
Thanks for your feedback
Submit
Need more help?
