Back
About Wi-Fi Calling and how to set it up
With Wi-Fi Calling from BT Mobile you can now call and text over wi-fi in the UK. This is great news if you live in an area with poor coverage and can't use your mobile at home; just connect via wi-fi instead. </.p>
With Wi-Fi Calling from BT Mobile, you can call and text over Wi-Fi in the UK. This is great news if you live in an area with poor mobile coverage and can't use your mobile at home; just connect via Wi-Fi instead.
You don't need an app as Wi-Fi Calling works in the background, so you can use your phone as normal. And it won't use up your data allowance either, as calls and texts come out of your monthly minutes and texts allowance.
It's available to anyone with a BT Mobile plan. You'll need a compatible device with the latest software.
Follow the simple steps in our Device Guides to get started:
  1. Go to Device Guides.
  2. Select your device make and model.
  3. Select Calls, contacts and messaging.
  4. Select Turning Wi-Fi Calling On or Off.
    Thanks for your feedback
    Submit
