Back
BT Mobile international network compatibility
When you go abroad, your BT Mobile phone will work just like it does at home. But to connect to some networks in certain countries, you may have to turn off 5G/4G and use 3G instead.
Once you've done that, pick a network from the list on your phone. If there are no issues with the networks in the country you're visiting, you may need to change your network settings.
Find out how to change the settings on your phone
The countries and networks where this applies are:
CountryNetwork
AngolaMovicel
Czech RepublicTelefonica O2
Dominican RepublicOrange Dominicana
FinlandDNA
GermanyDeutsche Telekom
HungaryT-Mobile
JapaneAccess
LatviaLMT
MauritiusEmtel, Orange
NamibiaMTC
PhilippinesSmart
PolandMobyland / CenterNet
Saudi ArabiaZain
SingaporeStarHub
Slovak RepublicTelefonica O2
SloveniaSi.mobil
UAEDu, Etisalat
USAT-Mobile
VenezuelaDigitiel
Thanks for your feedback
Submit
