Back
BT Mobile: I'm having trouble using mobile data abroad
When you get BT Mobile, we'll send you some texts to help you set your device up. If you don't follow the instructions properly, you might have trouble using mobile data abroad. All other services should work normally.
You might need to check and change your device settings:
How do I manually set up my phone to work with BT Mobile? >
There are also a few countries where data roaming doesn't work >
Thanks for your feedback
Submit
