BT Call Protect is a service that will send nuisance and unwanted calls to a junk voicemail. It will help to stop the worst offending nuisance and scam calls, as well as providing you with the control to stop other unwanted calls. It’s simple and easy to manage.
Find out more about Call Protect.
There are five main types of unwanted calls:
In addition to activating BT Call Protect, you should also ask the company to stop calling you and remove you from their calling list. Some marketing calls start with a recorded message. Listen to the whole message, as some have an option that lets you stop these types of calls from the company.
You can also cut down these calls by signing up for the Telephone Preference Service. It's free to sign up and makes your phone number unavailable to companies that might try to call you. Once you're signed up, you should only get marketing calls from companies you've allowed to contact you.
We also offer Caller Display which allows you to see the number of the person who’s calling.
Fraudsters often make calls claiming to work for us, but it's actually a scam. They may ask you for personal information or want access to your computer. Don't be fooled, this is fraud.
For more information, or to report a scam call, visit www.bt.com/help/home/scams/.
Malicious calls can be upsetting, but you can take some simple precautions when answering the phone.
- Stay calm and don't talk to the caller.
- Don't give away any personal information or answer the phone with your name or number.
- Keep your voicemail message short and to the point.
- Keep a note of these calls.
If you're getting abusive, threatening or obscene calls, then you should report them to the police. It will help if you note down the date, time and number that was called, along with any other information.
Calling features that can help:
- BT Call Protect - sends nuisance and unwanted calls to a junk voicemail.
- Caller Display - Lets you see the number that's calling you before you answer.
- BT 1471 - dial 1471 to check the number that last called you.
- Ex-directory: take your number out of the telephone directory.
Many silent calls come from automatic dialling equipment in call centres, where more calls are made than operators are available to handle them. To help stop these silent calls, you can register your number with the Telephone Preference Service.
We also offer Caller Display, which allows you to see the number of the person who’s calling.
You will receive text calls if you've been sent a text message and don't have a text enabled phone. An electronic voice will read the message out.
You can stop them by calling 0800 587 5252 from the phone line you're receiving them on.
