Back
Using your hearing aid with a phone
Follow these steps to use your hearing aid with a mobile or home phone.
In-the-ear (ITE) hearing aids
  1. Switch to your hearing aid’s ‘T’ setting, if it has one. If not, use it on the standard setting.
  2. Hold your phone up to your ear and move it around until you get the best volume.
  3. Avoid holding your phone flat against your ear as this might cause a whistling noise.
  4. Use your phone’s volume control or speech amplifier as normal.
Behind-the-ear (BTE) hearing aids
  2. Hold your phone against the back of your ear, close to your hearing aid.
  3. Move the phone around until you get the best volume.
  4. If you hear a whistling, move your phone further away from your hearing aid.
  5. Adjust your hearing aid volume, if needed.
  6.  Use your phone’s volume control or speech amplifier as normal.
If you find that your hearing aid is picking up interference on calls, you can use a neck loop. This will keep your phone away from the hearing aid and reduce interference. Or you can use the loudspeaker setting on your phone.
Using a phone with an inductive coupler
Some phones – e.g. hearing aid compatible phones and all BT payphones – contain an inductive coupler.
When using a phone like this, follow the steps above as you would with any phone. But if your hearing aid does not have a ‘T’ setting, you’ll need to check your hearing aid manual for instructions on pairing your hearing aid with an inductive coupler.
Need more help?
