Back
TNT Sports recording problems
Please try these steps:
  1. Check other TNT Sports recordings to see if this was a temporary issue.
  2. See if you can record a new TNT Sports programme.
If the problem only affects your TNT Sports recordings, and you've still got issues, then please call us on 0800 111 4567.
If the problem affects all recordings (not just TNT Sports), then there may be a problem with your set top box. You'll need to speak to Sky or your satellite service provider for further help with this.
You can also have a look at the FAQ on Sky+ - Will I be able to use Sky+ features with TNT Sports? >
Sometimes live sport can over-run, messing up the TV schedule. For example, a football match can go into extra time without the TV guide being updated. Programmes on afterwards might then show later than planned. It can be exciting when this happens during a tight game, but unfortunate if it means your recording misses the end.
It's worth checking other TNT Sports recordings, to see if it's happening all the time.
If the problem is affecting all recordings, not only TNT Sports, then there may be an issue with your set top box. If you're watching on the Sky Digital Satellite Platform, you'll need to speak to Sky or your satellite service provider for more help.
If you regularly lose recordings and are watching on EE TV, please call us on 0800 111 4567.
Thanks for your feedback
Submit
Need more help?
