Back
BT Wi-Fi Care: automatic Wi-Fi optimisation
This article explains BT Wi-Fi Care. It’s an automatic service feature included with BT broadband that looks after your Wi-Fi, keeping everything performing at its best.
BT Wi-Fi Care runs in the background to keep your home Wi-Fi performing reliably. Included for customers with a BT Smart Hub 2 or BT Smart Hub 3, it automatically monitors and looks after your connection, so you do not need to make any changes yourself.
When your broadband is installed and set up, we run a connection health check to ensure your hub software is up to date and working as it should. BT Wi Fi Care then always stays active, applying ongoing connection tweaks and automatic updates. We will also alert you to major service issues, including known outages and the expected duration of repairs.
This means your connection is always handled with care, with no action needed from you.
Good to know
BT Wi Fi Care uses only your network performance data. It does not access your personal content or browsing history. For more information, please refer to our Privacy Policy.
How BT Wi Fi Care works
BT Wi-Fi Care focuses on keeping your home Wi-Fi balanced and reliable, even as demand changes throughout the day. Your BT Smart Hub automatically chooses the best Wi-Fi channel and frequency for each device. It considers factors such as interference from neighbouring networks, helping deliver a more reliable connection throughout your home.
No action required
Everything happens automatically. There is no manual setup or intervention required. We install the latest updates, without disrupting your service, to keep your connection fast, secure, and ready for everyday use.
Peace of mind
We'll send you SMS alerts for major outages and let you know when your broadband is working correctly again.
Future ready
Automatic software updates help keep your hub secure and compatible with the latest devices. We also continually monitor your hub and network connection in the background to make sure everything is performing as it should.
Self-help options
You can use the My BT app to check your connection status or optimise your Wi-Fi with a single tap.
Thanks for your feedback
Submit
