Here's what to do when you've previously connected to EE Wi-Fi hotspot, and want to switch back to your BT Hub.
Here are some answers to help you
Why do my devices keep connecting to EE Wi-Fi instead of my BT Hub? -
I have problems connecting 5GHz and dual band devices wirelessly to the BT Hub See how to solve the problem caused by dual band devices not coping with single log-in details
Connect to a BT Hub using wi-fi Discover how to connect to the internet on different devices wirelessly, after you have set up your router with BT - follow our useful guide.
How do I connect my device to my BT Hub by Ethernet cable? Connecting to your BT Hub with wires gives you the fastest and most reliable broadband connection.
Go back to: What type of connection problem are you having?
